doitall
1) i'm not a combi boiler doktor..... i have 35 yrs in the game, Am gas safe registered and an expert in all aspects of heating, commercial, industrial and domestic!
If you cared to read the threads you will have noted that a cylinder...and hence a system boiler is out of the question! read properly before you decide to add your d.i.y. penneth worth. Tomorrow i am fitting a ground source heat pump while you are probably painting and decorating!!
That is so funny I like you already
Combi Boiler Doktor, are you any relation to Dr Drivel and Water Systems
The boilers only role is to heat the water for the 1 bathroom which will consist of 2 sinks, a shower with spray jets, and a whirlpool bath which has a pump.
I am not sure, but the shower (may) need a small 1.5 bar pump as well. I have very strong almost torrential cold water pressure due to the supply flowing downhill to me.
I've copied the spec again for you Dok, keeping in mind there's no heating, what Combi would you like to change your boiler selection as the 440 may not be too happy in the above installation, unless you know best Dok.
Talking of not being happy, your selection may upset a few guys in the regulation making department as well.
In case you didn't know, the 440 would use a bottle of gas in 19hrs, how much are they now £60 for a 47Kg
Next you have to explain why a cylinder and system boiler is out of the question, if the OP goes ahead with what he has planned, It's the only option
As the only DIYer in the Combustion Chamber, I'm sure you can continue my education if they let you in, although I get the feeling it may be the other way round.
TaTa for now BoilerDoktor, I'm sure we'll get on famously.
