Hi
i've just replaced a 6.5kw shower with a 8.5kw shower, the problem i have is that the 30amp mcb trips after about two minutes, so i've stopped using the shower.
I was told that the 6mm cable needs to be changed to 10mm, so i have just rang an electrician for a quote but he says 6mm is ok for this size shower but i will need a 40amp mcb, would you all agree with this.
If so, any ideas where i can get a crabtree c50 40amp mcb from.
Cheers
Cheers
