Jesus this the simplest timer given to man! A1 time on A2 time off A3 time on A4 time off.. The sun setting is temp u want when on, say 21deg ,..the moon is temp u want when off say 12deg, then slide to run an switch on auto to take effect. If you put on sun mode it will be 21deg as that's what u set in the sun setting, if u slide to the moon it will be 12deg as that what you set
