Silicone around cable
7 Dec 2018
Hi All,
In this cold weather I need to seal around a cable coming out a wall. Do i wait till the temperature rises to at least 5 degrees for at least 24 hours or can it be applied as is and it's just a longer setting time. I've got some clear soudal general purpose to use.
Look at tte data sheet for your silicone online.
That will tell you about application and temp.
From memory it's around 5c your fine. Variations in brands though.
Most I've seen say minimum 5 degrees, think I will wait till its got to that temp for 24 hours before sealing.
