[url=http://www.telegraph.co.uk/property/main.jhtml?xml=/property/2007/04/17/pask117.xml]Telegraph[/url] said:
...Mould in the bath
Q. The sealants I use around baths and showers all seem to be covered with black mould within a few months of application. I have tried various brands of acrylic and silicone sealants, which claim to have "superior mould resistance", but after a time black spots appear. Is there a truly mould-resistant sealant or any other solution to this problem? KM, Sunderland
A. Sealants that manufacturers claim to be mould-resistant incorporate one or more fungicidal chemicals, but in such low concentrations that the sealants are not subject to the Control of Pesticides Regulations (which would impose restrictions on their sale and use).
So their fungicidal properties are limited to start with, and it is also accepted that fungicides have a high vapour pressure which means that they evaporate quickly. Therefore it is unlikely that any type of bath sealant will have an effective fungicidal component after a month or two of being applied. If you read the instructions on the packaging, you will notice that the manufacturers do not claim any kind of timescale for their alleged mould resistance.
Moulds will germinate and grow on any surface if the temperature and humidity conditions are suitable. Bathrooms provide the ideal conditions, and the only way to ensure a mould-free bathroom or shower room is to provide much higher levels of heating and ventilation than most people are prepared to countenance.
Silicone sealant seems to be an ideal platform for black mould growth. Some experts suggest that the problem is exacerbated by the common practice of using a wet finger, or a tool dipped in soapy water, to smooth off the sealant when it is applied, since this moisture is absorbed into the surface of the sealant as it cures, allowing for rapid mould growth.
So the current thinking is to avoid wet smoothing methods and to use a dry smoothing tool such as the Fugi (from Cramer UK, 01934 713377). If you already have mould-stained silicone sealant, try a hydrogen peroxide-based cleaner such as HG mould spray (available from tile shops and plumbers' merchants)...
