Not much experience with radiator boilers so excuse any ignorance in my question, but our Format 34i boiler seems to be operating in "binary", rather than "modulating" mode for some reason. That is, instead of the burner staying on and holding the water temperature reasonably steady while there is demand from the room thermostat, the burner turns on and off constantly. The temperature range showing on the dial fluctuates between a very narrow range, maybe 70 degrees at minimum when the burner fires, to say 73-74 degrees when it cuts out again. This is with temp dial at max. Naturally, the room never gets anywhere near the set temp (manages about 21 degrees at best after hours of the system being started). Boiler used to operate well, modulating to keep water temp at around 90 while there was demand from the room stat. Can anyone advise where I should start looking to diagnose this, or suggest what parts might be in need of replacing? Sick of cold rooms!
Any hints greatly appreciated
Steve
Steve
