Apologies if this is a stupid idea - I'm a new kid on the block.
Am upgrading CH pipework into 3 loops from Bosch Combi 28CDi RSF (sealed system) and would like to do so without changing the boiler setup.
Plan to use Valve V4043H (2 port) with its own mains supply and Thermostat 6360B (independently of the boiler) at the start of each loop.
The theory being that each loop would close down when above the stat setting, and the boiler - with its own stat set higher than the loop stats - would carry on feeding the other 2 loops. The changes in system pressure would be taken care of by the AutoBypass Valve DU145 fairly early in the system.
I appreciate that this is an unconventional solution as I'm not linking the valves back to the boiler, but does anyone see any technical or Building Regs reason against this idea
