This is a slightly strange one.
The central heating pump of 25 years old finally died so I replaced it with a grundfos one. All appeared to work fine until I noticed that the old potterton boiler was coming on and the circulation pump was running despite not being set to come on.
I replaced the drayton mid position actuator and the issue persisted. I removed the back of the water/central heating programmer to find the relay contacts stuck together.
I separated the relays and all was well for a while until it did it again. I replaced the programmer (drayton LP241)and it has done it to the replacement one also.
I separated the relay contacts again and it will switch for say 10 ten times then latch. Its like the starting current on the pump motor is damaging the controller relays.
The pump is not pulling crazy current when running and seems free to turn. but somewhere in the circuit the current is sufficient to latch the relay contacts together.
Could a failed pump capacitor be causing the start up current to latch the relay contacts together?
is there anything else in the programmer relay circuit that could be causing this issue? help!!
