So pleased I found this bulletin as I've just been experiencing the very same problem with my mothers central heating and its been doing my head in! Same thing; heating engineer came around to replace failed pump with Grundfos UPS2, shortly afterwards the original programmer (Danfoss LP2) failed in the on position. Thinking this was just coincidence I replaced the controller with identical and within days the same thing had happened e.g. failed on. As I'm an electrical engineer I carried out a full wiring check including tong testing the new pump - nothing showed up as wrong. I blagged a third programmer from the supplier claiming the first one was duff and same happened again. Now I realised this started when the new pump was fitted so I knew it had to be to do with that but couldn't prove it.
Nice to know there's a fix!
