Hi all,
I've just moved into this house and the living room radiator isn't heating up. I've searched through the internet with a lot of guides but it seems (at least in my unexperienced opinion) that my problem is a little unique.
This living room radiator doesn't have a TRV - both sides have the little caps which covers 2 lockshield valves. These valves are both fully opened (turned anti-clockwise). This radiator is controlled by one thermostat also in the living room (I'm assuming this but I think it makes sense), whereas the rest of the radiators in the house are controlled by a thermostat in the hall. The other radiators all heat up fine.
I've tried bleeding the radiator, but water comes out immediately. The pipes at either end don't heat up at all when I put the thermostat to a high temp but I can hear the boiler working when the thermostat screen indicates the little ignite sign to show it's trying to heat up. I've been playing around with it and noticed that the boiler also displays the heating signal when I switch on the living room thermostat (with the hallway one off).
I'm a complete novice when it comes to this stuff and I'm figuring out how to balance the radiator to see if that's the issue, but I'm not sure if there's anything specific I need to do since this radiator is controlled by the one thermostat - would I need to close off the lockshield valves on all the other rads and turn on the hallway thermostat as well? I also have a combi boiler if that makes a difference.
I've already asked around on the internet and I'm fairly certain I'll need someone to come look at it, but thought I'd ask here before that
