Single steel or double steel?
30 Jun 2011
Berkshire
Hi there, I have a structural engineers drawing showing a steel beam spanning a knockthrough for an extension.
When I showed the drawing to the steel fabricator he said that the drawing suggested it was two beams running in parallel. However I had been under the impression that I only needed one beam. It will be sitting on and supporting a solid brick wall approx. 230mm thick.
The beam(s) are noted on the plans as 203uc46 if that helps.
Does this sound like I need a single or double beam?
Do you need more information to answer this?
(Engineer is no on holiday for a couple of weeks so can't go straight back to him)
cheers,
martin
That's exactly what i thought. The engineer must have done it last thing on a friday i think!
So a 203 wide beam sounds acceptable for a 230 thick wall?
Cheeky supplier trying to flog you 2 lengths of PFC to increase the price?
