I am putting in a new kitchen and want to know if there is a safe or "building regs" distance I can put a gas hob next to the side of a larder unit ???
Not sure for a ladder unit, a under worktop unit must have end panels between the oven and units (20mm) each side. Ask the kitchen suppliers for advice on the regs. It surely can't butt up tight!!!otherwise the ladder side panel(white edge to unit), or ladder end panel( if fitted) will overheat and blister. Heat rises !!!!!
