Just done my skirting boards with a little help from my joiner mate.
If the walls a perfectly straight and the boards will sit nice and flush then you can "no nails" them as there a no screw holes or any filling to do. But, like with my house, the walls are not straight so we drilled and screwed them in.
After i'd screwed them in i filled the holes with wood filled and now have stained the skirts and you cant see any holes.
If the house is fairly old (mine is 24 years) then i dare say the walls will not be straight.
Easiest way to find out just find the longest striaght edge you can and hold this up to the wall.
