I recently installed a new gravity fed shower but now the thermostatic shower valve keeps blocking with 'slime' on both the hot and cold supply sides (every couple of weeks). The 'hot' side had a completely blocked pipe (relieved only by pumping air bakc up it). Both supplies come from a loft header tank (hot via the cylinder, cold direct) which turns out to be full of slime.
Toilet cisterns and loft header tank have started to overflow - you've guessed it, ball valves weighed down by slime/valve assembly blcoked by slime.
What is all this slime? Other than draining and flushing/cleaning is there anything else I should/could do? Taking the shower valve off each time is a pain!
Been in this house for 14 years and this all started recently.
