Hi Guys, hoping someone can help me here
A week ago, I heard gurgling sound up in loft found vent pipe overflowing hot water into header cistern - called plumber, he replaced faulty cylinder thermostat but that didn't fix problem - eventually traced problem (we think) to boiler - boiler thermostat set to 2, but it always "clicks" between 0 and MIN = way too low - temp sensor is working fine, it just isn't getting very hot (poked into hole near top of heat exchanger) - suspect sludge (or something) in heat exchanger is preventing heat transfer to heat sensor ?? It's a 20 year old Potterton Kingfisher II, never had a problem with it. Plumber drained some water out of radiator drain plug, water seemed ok.
Plumber talking about full system power flush at £600, or new boiler at £2000 !! Eek.
I called Potterton tech support, very helpful, they seemed to say flush out the heat exchanger, which makes sense - and they said it's ok to use strong chemicals cos it's made of cast iron.
Does this sound the right thing to do ?? Is that an "easy" job (compared with full system power flush) ?? Just don't want to spend £600 or £2000 if we can avoid it.
Thanks for any help with this !!
David
David
