Last saturday i drained down my central heating system in order to clean out the feed and expansion tank. This was recommended in my home survey before i bought the house.
I noticed that there was a lot of sludge in the bottom of the tank - about and inch deep of the stuff! Not the most pleasant stuff to clean out but I bailed out the tank and removed all the sludge. I then rinsed through the entire system before securing the ball valve and bailing out again.
I then poured a litre of Wickes system cleanser into the feed pipe before releasing the ball valve to refill the system.
Having run the system with the pump set to the third most powerful setting for three days i then popped back into the loft to have a look in the feed tank. Yet again the water was dirty and appeared to have sludge deposits in it.
What i can't understand is how it is getting there! Any ideas?
My setup is pretty much as in this diagram: http://www.sjsplumbingservices.co.uk/images/systemdiagram.gif
Any help greatfully appreciated![/url]
