You are correct in that the mower has a two pin non reversible charging socket, but I can assure you the 827H does not have an inbuilt alternator charge facility. The equivalent Stiga machine also does not have an in built charging system either as far as I am aware (not100%), but the 827H definitely hasn't.OK I can't comment for certain but all ride on machines I've ever come across have a charging system. I can't find a full spec sheet either.
All Mountfields do come with a battery charging point though, a two pin non reversible socket which has a round and flat locator to prevent incorrect connection.
John
So have you confirmed this by connecting a meter in series between the battery and removed terminal with all switches off?The symptoms are that the battery seems to be discharging without any load being demanded from it, hence my suggestion of an unidentified battery drain with all systems isolated.
No - In order to remove the positive terminal from the battery requires is to be unsoldered (it is not a simple spade connection), To do so will invalidate the warranty.So have you confirmed this by connecting a meter in series between the battery and removed terminal with all switches off?
The article you refer to is great link, but the details are general to Sit on Mowers.This, seems to suggest, that the Mountfield does in fact have the ability to recharge the battery, via the engine running. Look at section 7.7, where it says
Electric start models...
The job of the charge system is to supply a flow of
current to the battery at a maximum voltage of 14.7
Volts; a defective system might not charge the battery
correctly (requiring frequent charging
That's the Very FELLA' for me
The New battery comes with a flying lead the remote end of which has a plug connection that plugs into the wiring loom of the mower. the the battery change is a simple unplug and plug in the new battery.In series with either of the two terminals will do it, but I have never heard of a battery being permanently being soldered to the loom, how would you go about installing a new battery - have you a photo?
Leave everything alone for 24 hours then the battery cannot energise the solenoid suggesting the battery has discharged without any load being applied to it.
Yes there is but the 'Female' connections are not very accessible, but worth a try, although it is being picked up for full refund early January.Are there any fuses you can pull, to put a meter in series with?
Exactly what I am doing, the trouble is with these things, you only know if they are good or bad after the purchase. I did my research prior to purchase and all seamed positive, maybe I just have been unlucky and acquired a Dud.Sounds like a crap mower, save up and buy something better
