Hi i have decided to build a small wind turbine fixed to my garage at the rear of the house before paying out for expensive turbine blades i decided to play around with a scrap ceiling fan this having 4 blades
anyway i stripped it down and recovered the front part that held the blades on
I decided to make my blades from 4" round plastic soil stack by cutting to 600 mm in length then placing a peice of tape from corner to corner and jig sawing it out that gave me 4 blades with the required shape to catch the wind i fitted them to my hub and used the old shaft on a bearing and connected it to a 12 ft pole wow it went around that fast it was pulling me over so now i knew that it would work without any costs involved for the experiment
I have now gone up a mode and purchased a 5 blade carbon fibre set with a hub and i have purchased a permanent magnet dc motor
that is used in the states a lot it will produce a voltage witchever way it goes round my plan is to use a bank of special 12 volt batteries
which are available on ebay and i will have a voltage regulator circuit
before the batteries to regulate the charge which should be around 14.5 volts and as the turbine will run day and night the batteries will soon get charged up i will then get 2 or three 12 volt elements and fit them into my hot water copper cyld so any current not needed by the batteries will heat the water even a small amount is better than nothing
i will be using an inverter to transfer 12 volts to 240 volts AC then i intend to run all my lights in my house from my own system i have worked out that all my lights if all on together takes about 600watts
so i will have 6 /110 amp batteries to do the job and even without much wind on odd days they will last a long time
i am also looking at combining solar pannels into the system,
well thats what i am doing but i am at a bit of a standstill at the moment as i am recovering from colon cancer opp, which was succsessfully carried out so i cant wait to get cracking again , and start saving some money on my electric bill
mick
mick
