read Direct HW Cylinder not the same thingit does not even have to have a heat exchanger, the solid fuel cooker in mothers house did not, the water in the tap and water in the boiler were the same, and it would some times actually boil the water.
Because of the way the WB electronics work as they wanted to make it exclusive to use their own brand of controls , was absolutely nothing to do with the Hive , stop living on Google, some actual installers know betterThere is a long list of boilers mainly Bosch which Hive will not work with
Page 8 on this guide was it so hard to link as I have done.Installation Guide said:Gravity-fed and part-pumped systems are wired differently to standard boilers. With these, the hot water relay switches on the boiler, whilst the heating relay opens a valve, operates a pump, or both, to divert hot water to the heating.
Now to suss out where to place the thermostat
