Tonight I came home to a cold house- when I checked the central heating (Potterton Prima F) the timer was calling for heating and hot water, and the exhaust fan was running, but the flame was extinguished. When I checked outside, there was a strong smell of gas coming from the flue. I turned the unit off at the wall, then powered it up again, and it struggled to light- it ran the purge cycle 5-10 times. I went outside and put my had over the flue vent and it fired up straight away.
The boiler has been running ok, but I have noticed that sometimes it runs the purge cycle several times before the flame igites.
If the flame extinguishes, surely the boiler should detect this and cut off the gas? Could the flame be blown out on a windy day by air travelling down the flue- it is situated 7ft above the ground on a side wall.
Presumably this needs urgent attention!!
