- Joined
- 7 May 2021
- Messages
- 3
- Reaction score
- 0
- Country
Hi
I'm really struggling with a bad sewer gas smell in my bathroom & need any experience or ideas I haven't already tried!
I moved in to a new house (new to me, but 50 years built). It has 2 bathrooms up stairs, the ensuite which is fine, and a family bathroom - which is getting a slight sewerage gas smell almost all of the time. Some days its worse, others not too bad. I've read loads of forum and plumbing advise most which suggest (1) air vent / AAV blockage / poorly fitted / needs replacing - so I've had a plumber replace it; the problem has not improved (2) p-traps under the bath / sink / shower being either evaporated letting bad air in to the room from the soil stack, or need cleaning - I've checked these and cleaned with gallons of bleach over night multiple times - I can't get any sign of a smell from any of them. (3) Blocked or backed up drains - I've lifted the manhole covered and they are really clean, slight smell but nothing you wouldn't expect from a sewer. Water is flowing fine.
The smell is really hard to trace to a specific place in the room it seems to build when the door is closed. If anything it seems to be worse around the loo.
There is no sign of any leak around the soil stack connector to the toilet.
The only thing I have not tried at this point is replacing the fitting from the soil stack to the toilet incase a seal has gone - but most places seem to say these seals are very unlikely to break, and if they do then I would see visible signs of a leak?
Does anyone have any ideas??
The soil stack goes down stairs and a cloakroom loo shares the same stack. That loo does not build up a smell. Nor does the ensuite which is on a different stack, but same drain / manhole.
I'm all out of ideas! More than happy to get an expert in, but at this point the plumber had no other suggestions, and seems unlikely to be a mains drain unblocker service.
I've resorted to a load of diffuser sent bottles which is pretty much just making a cocktail of rancid stench!
Any help would be great! thanks everyone.
