Smoke Detectors
31 Mar 2006
Yorkshire
I am currently first fixing a new house that I am doing up to move into. I am planning to fit aico smoke detectors, as I normally fit in other rewires, however I am fitting a Texecom premier 24 & com2400 module. I would like the smoke detection system to be able to trigger the outputs on the alarm.
The original plan was to fit an aico relay base under one of the smokes & connect the alarm to that, but it got me thinking why not just do away with the mains smokes, fit an alarm expander & run telecom smoke & heat detectors back to that.
My question is would this then comply with building regulations or do the smoke detectors have to be directly mains powered?
Adam
No, you must fit a proper interlinked smoke alarm system to coply with building regs.
Fit a relay to trigger the alarm by all means, but you can not rely on it as sole means of fire detection.
Thought that would be the case, just seamed a good idea.
What market are the exodus smoke & heat detectors designed for then. Surely they can't be used in a commercial environment either.
Thanks for the help.
Alarm installers sell them to their punters as part of the alarm package. They are rubbish anyway. If it's your own home then 100% go with a proper aico system. I've got a relay base on mine but never actually got around to connecting it up to the alarm.
I put the relay base in a gewiss box in the loft so you don't end up with an unsightly base under one of your detectors.
