Thats interesting, not seen one of those, that should be the answer to the problem.e.g.
Not sure I follow that Harry, I may have missunderstood you though.It often happens, it cannot be easy, getting it level around a protruding box in the wall. If the high part, is above the edges of the box, the OP may be able to sand the high spots down some.
Providings that the box is flush or lower than the existing level of plaster then plastering flat and level to the local plaster is not a big problem. Only if the box is seated proud above the plaster level (example at one corner) will there be a problem
|Agreed Harry, but my point was it would be the box that is not sited correctly - flush or below.
Although most plasterers would probably be able ti improve things a bit if it is only a bit that is needed but it would be the box not the plastering that is in error
But if you think about it, all that will achieve is the socket will stand out of the wall by 5mm and you will still have a gap to the wall that you have to fill! Listen to your wife......Thats interesting, not seen one of those, that should be the answer to the problem.
Given that my mrs wants me to just leave it and thinks i am fussing over nothing
oh yes of courseMaybe, or it could be the plaster, trying to skimp on plaster use.
