Steve said:2. no you cant. The cable must run in safe zones. To accomplish this you can put a blank plate and backbox above the door, on the cables path
It will show people there is a cable and stop them drilling, since there are safe zones horizontally and vertically from every electrical accessory (switch/socket) which you must adhere to. There is also a safe zone to 150mm from the ceiling. If you put your cable here, theres no need for the blank plate.Tony 1 said:Steve, what will that do?To accomplish this you can put a blank plate and backbox above the door
Tony 1 said:Just an idea, instead of running vertically down from the existing socket to the 5 amp switch in the diagram, can i go horizontally left out of the existing socket through the 5 amp switch and then vertically up into the light switch before continuing vertical up to the ceiling, like this?
http://img205.imageshack.us/img205/2314/plinth2mg0.jpg
Thanks very much.
davy_owen_88 said:No he doesn't. The safe zones are horizontally AND vertically from any accessory, as long as the cable changes direction within the safe zones it is fine.
