Hi all, a bit of an odd one (trying to save money again!)
I have a garage which is attached to my property with a fluorescent light inside. I have traced the cable for this back to the fusebox, and for some reason it was run in with 2.5mm T&E with a dedicated 10A fuse.
I want to put a socket in the garage, and as there is already a dedicated fuse and 2.5mm cable - would it be acceptable to change the fuse to a 32A, then divert the cable in the garage to a socket, then from there to the light?
