Hi. I'm installing a washing machine at home and want to plumb the waste into the soil pipe. The soil pipe is boxed in with limited space inside (10cm between pipe and box wall). I need to fit a 90 deg elbow as it won't be possible to boss straight into the pipe due to practically zero space behind plus the need to core through the wall.
All the boss fittings I have seen are either push fit or use a rubber boss adaptor. Are these ok to use in inaccessible area's? Can I just push a solvent weld pipe into this? (a push fit elbow + boss exceeds my 10cm limit). Any other idea's?
Thanks in advance.
Thanks in advance.
