Solar power Question
29 Oct 2008
London
Hi everyone
Is solar power worth looking into? I have heard it costs so much to install, and then it can only heat your hot water cylinder and cannot reach temepratures enough to provide central heating in winter.
Is there any way I can learn some more on solar power?
Any help would be great :D
as a business - don't bother unless you are going to employ slick weasel salesmen!
as an investment, fitting your own - worth doing as you will save a good amount pay back in around 5 - 6 years
as an investment getting it fitted will never pay for itself, you will hopefully break even in about 13-14 years by the time you take in maintenance costs.
solar reverse heating will probably only give a 10 - 15 degree rise on the heating water temp in the winter if that and only if the installer does it right!
Thanks for yor advice
Is it for new builds only then?
I was just wondering how it'd work !
You can use it for space heating with a thermal store, although by definition, the gains will be very limited. It will however be very useful for hot water.
Get a MCS registered company to fit PV panels and take advantage of the feed in tariffs. It is worth looking into.
