solar powered welding mask, is it working? Newbie question!
28 Jul 2015
OK, thought I'd have a go at welding after buying a MIG welder from a neighbour. Bought an second hand auto darkening helmet from someone else.
The helmet is a solar charging version (spargo) but there is no battery slot, similar to this solar welding mask.
Left the unit in the sun for a day, but when I change the sensitivity, delay or shade nothing looks any different when have it on... or when looking at the sun, just a green tinge.
Should I be able to tell if this is working or does it only work when welding?
Chibs
When you have the helmet on, look at a fluorescent light.....the auto darkening should trip.
The 9 to 13 scale is used for light welding current applications (9) to heavy arc (13).
John :)
Fluorescent light... what's this... the 80's ... hahaha :LOL:
Thanks gents, will try this out.
If this helps anyone else...
Couldn't get anything out of the mask. Neighbours live with 80's lighting, so did a bit more digging.
Found a video on U-tube, looks like there is battery in this unit, I've taken mine apart and it's the same as this, ordered a CR2430 and will report back.
thanks all.
just had a play with mine, Fluorescent trip it, and so does mains powered LED's, in fact any mains powered lights trip it. But battery powered LEDs (DC) don't trigger it ? neither my super bright led bike light or the intensely bright headlights on the car.
what's all that about ?
oh yes, and mine is a solar powered one, it has to be unused in a dark cupboard for weeks or longer before it stops working
I think these things respond to light in the UV and IR spectrums, but don’t quote me on that one!
I’m wondering if these helmets all have a battery inside charged by solar - I don’t know.
John
it can't be UV otherwise the sun would trigger them, and yet piddly little 7w flourecent triggers them.
and yes there must be a battery of sorts to hold the charge for weeks, don't think you can do tht with a capacitor
They apparently use 'arc sensors', I have yet to find out what they specifically sense, but I will keep looking! :)
could it be its the 50hz that is fooling the sensor into thinking there is an arc ? this might explain why car LED lights and tourch LEDs and the Sun are not triggering it ? and why most household 240v bulbs, incandeccant, flurescent and LEDs all do
So far my research has only led me to one of my favourite websites: Hackaday
It seems that the particular model being hacked has an IR sensor. The microprocessor then interprets pulses/flashes of IR as an arc forming.
So theoretically, as in the video, the arc sensors in the helmet should be triggerable from the pulses of an ordinary remote control! :)
Just tried it with two different remotes and they both trigger it. Need to hold the remote within a few inches of the sensor thhough
