Hello
i have never really done any soldering or welding.
my niece has some cheap girly headphones, that to be honest cost less than £10 as she liked the girly headset, I would rather her have a better headset maybe wireless. Anyway she is 4, can’t blame her, but she accidentally broke the 3.5 connector. She asked me her autistic uncle to fix, I said I will try so I did. I got the new pin, this needed some solder to hold it, however the wire was so thin, it just turned to ash before any soldering happened, just heat from the 3.5 connections.
I took it on to myself to put new wire in the headphones, however I must of used so much soldering wire it’s unbelievable, and even then I only have it just connected. The cap for the 3.5 connector is too small to get past my first (ground/earth or whatever it’s called) connection as my soldering is bad.
I have however managed to get the headset working and playing music at a decent level now, although I had used those break off connection strips as I needed to work out the wires were in the right place.
I plan to make the headset Bluetooth, by that I am going to add a stand alone Bluetooth receiver and connect the headset 3.5 pin to the receiver, making sure the wires are not that long.
also, how is the best way for the solder to “stick” to a the wire, b connection ports?
