R
roberta1000
Re the crimp question (yes - I know the OP doesn't have enough space). Crimps are electrically better than soldering all things being equal partly because there won't be any ongoing corrosion and partly because they wont weaken the original wire even if its flexed a bit. Solder joints do both of these.
And each to their own but there is no way I would do a solder joint like this. Too little space to make a good joint, no way to remove the flux residues, hit or miss with the insulation (barrel of the soldering iron my foot!). Screw fittings or crimps for me even if it means a bit of cutting back.
