i want to have a go at some copper pipe soldering. i have had some practice but i seem to get messy joints. also how do you judge when it is hot enough. should you hold the solder on why it melts or just dab it on in several places?
No.are they with the small bottles?
It is like some utterly useless sh1te, but in a bottle.just seen this too http://www.solderlesscopperbonding.com/pg/index.html
wonder what that is like
Hi guys, how on earth do you get solder in areas which you cant reach.
For example say you have a joint which is near a wall. You can solder most of it but the part which is next to wall as well as the underside, how do you get solder in these parts?
Btw Im referring to a pipe that is horizontal.
Furthermore, how would you solder a joint vertically. The top joint on a straight connector would be straightforward but the bottom joint would be difficult as the solder would have nothing to sit on
