If eg the odds a any numbers coming out are 20 million to 1 then you could expect 1234567 to come out once in 20 million draws. Equally they could come out 10 times in the same number of draws or once only every 40 million draws.
So saying those numbers haven't ever come out proves nothing.
Wasn't the lottery lucky that you discovered a better way to become rich
I am not saying you are wrong, and I don't deny that the odds of any 6 numbers coming out in any sequence should be same as 1 in 13,983,816 but, this is only on a paper, in practice the odds may be extremely high or for that matter extremely low, depending on the trend by which the balls are drawn, so in other words the way the machines select balls, is different to the way a computer may select 6 numbers from 49, since there are no external factors that can influence numbers on a computer, such as how balls are distributed inside the drum, and how many spins it turns, how mass of balls and collision and resultant forces redistribute balls and the selection process isn't the same as theoretical process, would a computerised system not cycle all 49 numbers and stop randomly at any given number instantly, with no external influence by gravity, mass, air turbulence, as happens in a machine before the first ball is pulled out, all that internal bouncing and shoving that goes inside the drum, it is a bit like playing on a pool table, when you do a break, a player can expect how the break may spread the balls, well apart from this my system i devised worked brilliant, and as it was based on a past trend, that means choosing only combinations of 6 numbers that favoured the past 20 weeks results, which means there is a tendency that the next 6 balls may be drawn from that tendency, AND of course it is not guaranteed, that is why I still had to tread carefully and not go mad and lose out all my savings, but i was glad it started to win me serious money, but I should say sadly that job contract rewarded me much more than if I had carried on, and who knows it could have gone either way, but the job contract i won was a sure way to get rich, and yes it made me richer. Please note I said richer, not Rich! For a short duration that I ran my plan, I took some photo copies, as in those days digital cameras were still far from few, and one couldn't take a picture readily, so some of the times I took photo copies of the actual winning tickets, where i could do conveniently, and other times I didn't bother, from just a few tickets you can see for yourself whether I was on a winning trend, you decide.
