A question to clear things in my mind, i want to fit a solid fuel Rayburn in France, it presumably needs to be an open system for safety but i have the following problem. The house has 3 stories but i can only get the header tank on the 2nd storey which means Rayburn on ground, hot water cylinder on first and header tank on floor 2. However i want to have radiators on floor 3. The Cylinder will be gravity fed and the central heating will be pumped. The only way i can see i can achieve this is to have a heat exchanger on the gravity circuit to heat the pumped circuit or is there an easier way to achieve this without having the pumped circuit pushing the water out of the header tank vent pipe. I have only fitted fully pumped before and while this will be professionaly installed i want to know what options are available so i know i am not being led up the garden path.
Many thanks in anticipation
