dont worry. This stuff is childs play with the correct advice. First things first is moister test. Must be below 75% rh! Get the result and come back to me/us for the next instructions
WoodYouLike said:Even so Big Tim, before installing the floor floating you have to make sure the new screed is as dry as possible otherwise the moist will be kept underneath the combi-underlayment and cause rotting and/or problems later.
Moist has to go first, sorry. Better to be a bit more patience than having to start all over again.
BigTim said:Was thinking of screed tomorrow, self level Friday and then flooring on Monday.. Area is 6m2 and will prob stick the heating on to help it along. Sound along the right lines?
mattysupra said:also dont try putting levelling compound down until screed is dry. Like woody said 1" a month in ideal conditions. And with the weather like it is now, you can add extra time on. Also dont try and force dry the floor. It will make it weak, Shrink more and crack.
mattysupra said:What is the depth your trying to cover? And not sure about the 3 days on the compound? do you mean 3 hours?
mattysupra said:Something not right here.. Not to sure if your mates know what there doing! Thing is that wood will not forgive any mistakes made in the prep work. It will fail!
mattysupra said:Yes thats about right. The screed will not bond to the correct shear strength if layed to soon, depending on what your using and if you use correct. Your floor does not need to be level. Just smooth! Also depending on what method of screed they are using, 50mm can also be to deep. Now for the tech bit
For fully bonded screed the surface of the concrete base should be scrabbled or shot blasted to remove contaminates, laitance and to expose the aggregate. The optimum thickness of the screed is between 25mm and 40mm. For thickness greater than 40mm there is an increased risk of the screed debonding from the base.
All screeds laid direct over dpm's (except for epoxy bonding dpm's ) must be considered as unbonded. The minimum thickness should be 50mm but, for certain kinds of floors, the screed may need to be thicker.
Simple stuff
