Solvent / Push fit Joints on 110 mm Soil Pipe
How many bends are being installed ?
Plan view below showing bends.
First curve directly behind toilet is a pan connector, then normal bend, straight, knuckle bend at wall (indicated with orange arrow), straight through wall, normal bend on outside to stack.
So just 4 changes of direction,then :unsure:
At back of toilet, current plan is:
a) pan connector, then standard curve - then the straight section
I don't know if it would make any difference, but at the back of the toilet there may be the possibility for:
b) standard curve directly from back of toilet, this then pushfit into another standard bend - then the straight section
If you can use a normal radius bend then use it, if not then a tight radius (knuckle) is there to facilitate fitting in a restricted space.
