Some advice please ...
9 Nov 2006
London
Hello everyone
I'm trying to replace a push-button (pneumatic) time delay switch in the stairwell of a four-storey house (it's one of four switches that activate the lighting). I want to install a Timeguard DS1 switch which is illuminated so you can find it in the dark...should be a straight swap but I can't figure it out. Partly, it's because the terminals on the two switches are labelled differently - see below...
Wiring to the existing pneumatic switch is Red (COM terminal), Blue with Red tape (NC terminal) and Yellow with Red tape (NO terminal). These need to be connected to Live, Switched Live and Slave terminals on the Timeguard, I'm not familiar with these labels and don't want to screw it up.
Can anyone help?
Thanks a lot
For that timeguard switch to work, you need 3 slave switches to replace the rest with. :(
I think you can get illuminated surrounds that fit any single gang accessory (ie. the old switch), not sure though.
