As mentioned on another topic, I'm having my kitchen redone and doing the prep work myself. I've had an initial chat to an electrician that will do the final wiring.
There are two existing sockets on the wall that going to have the main work surface, they are link on the ring. The plan is to break into the ring to feed the power points on the counter top. Up to the centre of the wall space above the counter, feed the sockets and back down to the other.
1) Are the cables allowed to run behind the wall if there is a hob there? brick wall with plaster, and thinking about the heat.
2) There will be a cooker switch along the same line, would the cable just go through the cooker switch box, or have to go around?
3) And more for curiousity, there will also be some fused switch spurs feeding off for washing machine, microwave, dishwasher. These fitted appliances also have a fused plug, is there any point in having two fuses in the circuit? and only fitting a switch above the counter?
