- Joined
- 7 Sep 2022
- Messages
- 3,286
- Reaction score
- 876
- Country
I've a 2013 Ford Galaxy with a 2.0 TDCi engine. For some time been having slight electrical issues; soon after shutting off the engine (but keeping radio on for example) see a "Low Battery" message on the dash. Occasionally a red battery light appears while driving (and I believe this is "smart alternator is operating in dumb mode"?)
If I check the battery with a multimeter I might find it less than 12v even after a run, and a couple of times recently I've read sub 12v with the engine running (but then when i checked again after 5 minutes drive it was reading 13.5v)
Other odd symptoms, the power steering jerking and being difficult to turn the wheel (kicking back against the turning effort) - I think this is something to do with low battery voltage as it appears to be an electric PS pump, and one time when it was doing it at night the headlights were flickering in line with the steering jerking
Also, a strange whirring/purring/soft whining sound that changes in line with engine revs - if the car had had a mechanical PS pump I'd have said the fluid was low, but it's not quite a sharp a sound as that, it's a bit softer and is present all the time, even when the steering isn't being used. Fluid level in the ps bottle is ok
There's hot/burning kind of smell, not as sharp/acrid as a cooking clutch, in the general engine bay area
At the moment I'm thinking to swap the alternator and see if anything changes, but the thing I was curious about is that the multi plug going to the alternator only seems to have one wire, and I thought Ford smart systems had 3?
