https://assets.publishing.service.g...l-certificates-of-cause-of-death-covid-19.pdf
Couple of interesting points in this :-
For example, if before death the patient had symptoms typical of COVID- 19 infection, but the test result has not been received, it would be satisfactory to give ‘COVID-19’ as the cause of death, tick Box B and then share the test result when it becomes available. In the circumstances of there being no swab, it is satisfactory to apply clinical judgement.
• That Covid-19 is a notifiable disease under the Health Protection (Notification) Regulations 2010 does not mean referral to a coroner is required by virtue of its notifiable status.
• If you are aware that a virology test for Covid-19 has been carried out, state the result if known, for example ‘Covid-19 (positive test)’. However, certification should not be delayed to await the availability of test results.
so basically if you have a cold or a sore throat before you die but no test result has been received then they can still write Covid 19 on death certificate.
Don’t have to wait for any test results before filling out a death certificate lol.
Referring deaths to the coroner
Covid-19 is an acceptable direct or underlying cause of death for the purposes of completing the Medical Certificate of Cause of Death
Covid-19 is not a reason on its own to refer a death to a coroner under the Coroners and Justice Act 2009.
Medical practitioners are required to certify causes of death “to the best of their knowledge and belief”. Without diagnostic proof, if appropriate and to avoid delay, medical practitioners can circle ‘2’ in the MCCD (“information from post-mortem may be available later”) or tick Box B on the reverse of the MCCD for ante-mortem investigations. For example, if before death the patient had symptoms typical of COVID- 19 infection, but the test result has not been received, it would be satisfactory to give ‘COVID-19’ as the cause of death, tick Box B and then share the test result when it becomes available.
In an emergency period of the COVID-19 pandemic there is a relaxation of previous legislation concerning completion of the medical certificate cause of death
