I have a Ariston clas HE38 combi boiler and control currently is via a Ariston Clima manager. the wiring to the Clima is a 2 core cable with 24v running down it to power the Clima with its display screen, the connection at the combi is a green push fit connection block marked flow, in the bottom corner of the board.
The hive receiver has a power supply, so just needs the 2 core switching signal to combi.
So do these 2 single core cables on the flow terminals at the combi board connect between 1 and 3 on the hive receiver or is it another connection on the board ?
The clima control unit and boiler appear to be rare with little info anywhere.
###edit### just found wiring diagram and there is a room thermostat connection, it is shown in the diagram with a link between its connections, mine has the link removed, I imagine this is due to the clima being plugged in. So I am thinking pull out the clima connection at the board and connect 1 + 3 on the hive to the room thermostat connection ?? I any ideas folks as I may be wrong??
