I'm in the process of building a shed/man cave. It's 5.5 X 2.5 m2 and constructed from timber. Due to budget constraints the floor joists sit on top of 22 equally spaced concrete piers. I've been collecting Rockwool insulation slabs to use in the walls and ceiling. I've used celotex in the floor.
I'd like the room to be as sound insulated as possible without spending a fortune. I'm wondering what sort of system to use for boarding out the walls. I understand that the key is to try and see you up any small gaps and I also realise that not having a concrete floor and the celotex in the floor isn't ideal but it is what it is.
So I'd like information on the best system to board the room out. I'm aware of foam tape which can be used between the joists and the boards and also no sound insulating adhesive which I plan to use anyway to seal up any gaps.
Also wondering whether it's worth double boarding with a gap between the layers?
as I say I don't really want to spend a fortune so just looking for some obvious pointers.
Cheers
Cheers
