Sour dough bread
So as not to confuse myself and the readers, I will call the '100' gm culture in the fridge- "Culture"
The mix that is prepared with culture to make bread, calling it Starter
All ingredients are proportional to amount of flour used. Let the flour amount be for this example be 1000gm
Starter will 20% (220gm), Water called hydration level (I set it at 75% your hydration can be lower 65% all the way to sticky 100%)) and salt is 2%- 20gm
Starter
For 500gm, starter** needs 33gm culture, 33gm water and 33 gm flour (total 99gm close enough to 100gm that is required)
Mix well and leave on the worktop. With active culture, the starter will more than double in height in around 5 hours at this time of the year. Warmer days will make the reaction faster, colder temperature reaction will be longer hence culture kept in the fridge else it would need feeding everyday
** Remember you have removed 33gm from culture jar. To restore the 'loss' add 16.5gm flour and 16.5 gm water and mix well. Return culture container to the fridge.
The culture will become active feeding on the flour mix, the surface of the mix will become convex as the mix rises. The surface will then go flat when the reaction peaks and as the food source for the culture is exhausted, surface goes concave and mix starts to collapse
When stater is at its peak, add 375gm of water to it and mix well. Pour mix onto the flour and mix well ensuring no dry flour base of container. Let the dough rest (Hydrate) for an hour
Add salt 10gm. Work salt into the dough. Remove dough out of the container and stretch and fold the dough till you notice the laminations created by salt addition are removed. Look at youtube clips on this process. Return dough to the bowl
After half an hour, grab hold of the dough in the container, stretch it (not breaking the dough) and fold it over the dough, do this around the dough five or six times. Gluten bond is being stretched, dough starts to resist the stretching action
This action is carried out every half hour, total 5 or 6 times. Now let the dough rest.
from time dough was made , 5 hour later the dough will have risen and will be jiggly like jelly. Search finger poke test
Youtube for further viewing
Next stage youtube for guidance on how to shape dough ready for baking
Whatever shape final dough, store in fridge overnight or till ready to bake. This is where flavours will be enhanced.
Baking option for me is two cast iron pots. I preheat the oven to 250 degrees with pots in the oven
When oven at temperature, remove pots and place dough in the pot. Score the dough surface to create weakness, lid on, into the oven. Temperature reduced to 220. Bake for 30 minutes. Lid off further bake for 15 minutes. remove pot and loaf. Enjoy
Other option is Create steam in the oven during the 30 minute bake by placing ice cubes, water bath or various other options. Reason for this is to stop formation of crust during oven spring till the final bake.
Cast iron pots- dough bakes in dampness that is trapped in the pot during lid on bake
View attachment 306974 View attachment 306975
Hot out the oven.
Unlike DP, my folding technique is poor, this was slashed with a small 'X' on the top before it went in the oven.
My starter is 100% wholemeal, the loaf is light malt & white flour, sometimes I sling in some wholemeal or whatever wants using up.
Nice loaf
Made two loaves with Feta cheese and dill
Time is 9.40am
Prepared starter to make bread
Flour (whole meal) added to jug
Culture in small jar that sits in the fridge (liquid on the surface was mixed into the culture before use)
66gm culture added to jug from above jar is replaced with 33gm flour (I use 1:1 mix of whole meal and white flour for this) and 33 water. Mix well. Return jar to fridge
66gm culture from small jar is added to the jug- 66 gm flour already in the jug- total 133gm
66gm water added and mixed well - will be around 200 gm total (20%)
I cheated this morning:
:ROFLMAO: Still planning on making my own though.
  • Like
Reactions: DP
The culture jar that sits in the fridge
Restored 33gm flour and added 33 gm water to replace 66gm removed earlier
Culture jar. The additions to jar are mixed and culture returned to fridge until it is required again
The jug starter is sloppier since flour I have used is all wholemeal
A little difficult to read but the graduation is 0.25 pint. Will let the starter ferment and will post further timeline pictures
Will look forward to timings etc, my technique is similar-ish, although I put everything but the salt in, to sit around for a morning.
Will try your method, will be interesting to see if it's any better(y)
  • Thanks
Reactions: DP
From quarter pint mark starter rose to past 1/2 pint mark as sown in picture below
Notice the air bubbles the culture has created in the mix. This active ferment will result in even spread of holes in the finished loaf
Note the surface is flat as I have allowed the starter to peak; reaction slows down and the starter comes to a stop hence the mix against the glass is same level as the rest of the surface. If the starter is not utilised, the surface of the mix would collapse.
Earlier picture of jar with culture- there was a liquid floating atop the culture. This is the indication that the culture is ”starving”, it needs food ( flour and water). This is the main reason why people who do not put their culture in a cold place like a fridge, need to feed it every day
Will Be making two loaves
One is 500gm strong white and 25 gm wholemeal
Other is 175gm porridge oats blitzed to flour and 375gm white strong. Never made such a loaf. Will see how that turns out.
Two doughs mixed
Then allowed to hydrate
Above dough was allowed to hydrate
Salt spindled on the dough
Then salt worked into the dough
Half hour later white flour dough
And dough with porridge flour
After half hour dough is stretched and folded
As dough is stretched and folded, it is getting less sticky and has a bounce
Odd air bubble is indicated time for next process
This is at 8.30 pm
Dough removed from bowl to the work top
Dough is stretched at each of the four compass points, folded to the middle, dough flipped with “seam” at the bottom
Using scrapper, dough ball shaped
Dough with lower hydration ( using oats flour), ball shape has less collapse
By comparison one improves one’s technique
Dough relaxed after one hour
Final shaping is as follows
Strong white and other is shown below
Compare height
Now placed in benettons for proofing in the fridge
Seems I've got more to learn, I've never let the dough rest before slapping into the banneton.
Everyday's a school day :LOL:
PS, love the worktop is it corian?
Heated oven to 250 degree C with two cast iron pots in the oven
Dough out of the fridge. Both had risen, one with oatmeal more so but white flour dough had better spring and softened when poked with finger
Once oven to temperature dough placed in pot and scored
Lid on, into the oven
Temperature reduced to 220 and baked for 30 minutes
