You should turn off the main switch before removing or inserting a fuse, as it will arc and spark and burn the plug-in connections.
If the load is heavy or there is a fault it ccan be quite disturbing.
if the fuseholder or surround happens to be cracked, or break while you are tugging at it, you might get a nasty shock. Main fuses are especially dangerous in this way.
