Sparks, is this an electrical danger?
Probably cross 'cos he had to go out?
You got me :mrgreen:
I am a good friend.
The "pull cord" is not attached to (or detaching from) the ceiling.
It is attached to a "Switch", which should be properly attached to the ceiling.
Think I found the purist in the group..
If the "Switch" is currently being held up by a "Rawl Plug" ("Trade Name" for a plastic "Wall Plug") - and screw -
the ceiling must be Concrete (or similar "Masonry"),
since a "rawl plug" is not a suitable fixing to use on/in a "Plaster Board" ceiling.
These were the Rawl plugs used and they are suitable in plasterboard
Respectfully, @FrodoOne it's the weekend. Can we not be so uptight?
However if left on, so no one pulling at the switch, then should be safe enough for a week or two, and a 15 watt bulb left on for two weeks will cost around £1.60 so just leave it on until you get there.
Oh I like this...
So it's perfectly fine to tell someone in a similar situation to just keep the light on, until the repair is complete as it costs 'peanuts'..
Very interesting. Thanks
Edit: Just seen @DetlefSchmitz post
Eric, I have regularly used PB plugs in cases where a fixing into timber has not been possible. Including ceiling roses and lighting pull cord switches.
I too agree that the benchmark is 5 kg. I didn't have any problems with the stuff pulling out. If the hole is a tight fit for the plug, and the screw is fat enough to open out the plug sufficiently, it'll be right as rain.
I would not be happy with a bog standard rawlplug type for fixing a pullswitch, a batten is pref. or at least a RediDriva type or one of those anchors, folk can inadvertently pull hard now an again too, mind you I have seen ceiling roses and pendants help up with double sided tape and a glass globe on the lampholder
