Hi All,
Been trawling the forums a bit on here but can't find a specific answer to what I'm looking for. Basically my man cave is upstairs with a loft space above it. I have a TV mounted to the wall and I'm now looking to wall mount my speakers to get a bit more space on my desk. The wall in question is the one between mine and my neighbour's house, so it's block work with dot and dab plasterboard.
I'm looking to run the speaker cable in the wall up into the loft space, along and back down to the bottom of the same wall where I will install a speaker faceplate. The problem I've found is that with dot and dab, the top of the wall into the loft space is sealed with plasterboard adhesive. Is it OK if I drill a narrow channel (enough for speaker cable to get through) into the adhesive or is this not really recommended? If it is OK then is it as simple as getting a really long drill bit and drilling down from the loft space?
Ideally then I can also wall mount my rear speakers onto a partition wall (where I can run the cables up into the loft space and drop down to the faceplate).
Appreciate any help, thanks.
