watered down recently![]()
Oh no, not wet T shirt time again............
why don't things at the pole get crushed?
presumably at the equator there is a certain amount of centrifugal force trying to send us flying into space, but as you're not moving at as great a velocity at or near the pole then why doesn't gravity cause you to get much heavier..?
Centripetal acceleration at the equator is 4*pi2*r/T2.Er, what centripetal force at the equator?
Your point being?And gravitational pull decreases by an inverse proportion in relation to the square of the distance between the objects.
Not doubting you here, but where did you get all this from, as it's been a while since I studied this sort of stuff and was under the impression that mv2/r was the centripetal force? (can't immediately see how this relates to 4pi2r/t2)Centripetal acceleration at the equator is 4*pi2*r/T2.Er, what centripetal force at the equator?
The period of rotation is 86400 seconds and the radius of the Earth is about 6400 km. This means that the centripetal acceleration at the equator is about 0.03 m/s2.
Gravity is about 10 m/s2. therefore you will weigh about 0.3% less at the equator than at the poles.
Just providing clarificationYour point being?And gravitational pull decreases by an inverse proportion in relation to the square of the distance between the objects.
It seems this fellow agrees with you
http://www.funtrivia.com/askft/Question25977.html[/QUOTE]
Actually got the formula from here....
http://www.alcyone.com/max/writing/essays/geostationary-orbits.html
The maths is not difficult.
so if you stood dead centre of the pole and put an arrow on the ground a foot away would it revolve around you?
anything with mass will be affected by gravity and also create it's own gravitational pull. So any temptation to spew out is counterbalanced by other molecules' (and its own) gravitational pull.ok so the smallest molecule at the dead centre would it actually be affected by gravity or should the earth be spewing out molecules from each pole continously losing matter?
