Monkey said:
While the results of this experiment may be consistent, as of yet it has not been independently verified, and we cannot treat it as such.
Quite right. The theory of relativity has stood for a long time. It'll take some very good experimental evidence to knock it down. Might I suggest that one way to improve the accuracy of this experiment is to increase the distance. It shouldn't be too difficult to set up a source and detector on opposite sides of the planet.
Meanwhile, what's all this time travel business. I keep hearing it on the news and I get the distinct impression that a lot of people are jumping to a lot of highly dubious conclusions.
What
could you do with faster than light travel? Well, one thing you could do, in theory, is look back and see yourself leave.
But is this really time travel?
I don't think so. All you're doing is observing what's already happened. You can
observe the effect (arrival) before the cause (leaving). What you can't do is observe the effect then go back and change the cause, which is what true backwards time travel would allow.
Maybe you've seen one of those diagrams in a physics book that shows a cone standing point downwards on top of another. The point where the two meet represents your present position in a 2D space (3D is too difficult to draw). The upper cone contains all the points that you can reach without exceeding the speed of light while the lower cone contains all the points that you could have come from.
So far so good but all the books I've read jump to a rather nebulous conclusion, namely that faster than light travel will allow you to escape from the upper cone (which it will) and
re-enter the lower one.
This is not at all obvious. It's not even clear that the lower cone (your past) still exists.
As I once said in another thread, to achieve true backwards time travel you would have to restore the universe to an earlier state, something that the second law of thermodynamics will not allow.
