Splitting Digital TV Signal
7 Apr 2007
Lincolnshire
Sorry if this is in the wrong section but i was unsure where to put it.
We live in an apartment that was built last year. We have one tv Ariel socket that is fed from the antenna on the roof. The site manager provided us with a splitter (a small T-shaped device that just branches the signal). One branch of the splitter goes into the TV in the living room and the other branch goes into a socket next to the original, which is supposed to feed the signal to the other aerial sockets in the apartment.
The problem is that using this splitter reduces the signal to the TV in the living room and makes it blocky, but the TV in the bedroom is ok. So it seemed to me that because i was splitting the signal, some kind of booster would be needed, but after a quick look on the internet it seems it might take more than i think. Just wanted some advice as to how i can get a good signal for all the TV points in my house. Thanks.
use a good brand of amplifier that specifically says its intended for digital TV
Is that because the other ones are for a terestrial signal?
At what point would i connect this?
1. At the point when the signal comes into my house
2. After the split to the tv, to boost that
3. After the split to the rest of the house
Or would the amplifyer contain a split anyway?
I have found this, does it look suitable;
http://www.maplin.co.uk/module.aspx?ModuleNo=33969&doy=8m4#overview
Thanks for the help.
Yes, one of those will help reduce the losses.
If there are bad joints in the aerial feed you may get reflections that mess up Freeview but an amp will help, generally.
TTC
You should use the amplifier on the cable from the aerial, so its aerial in, then out to your property & out to other property.
