Splitting meter tails for two CU's
25 Mar 2006
Essex
Hi, I know I can split the meter tails to accomodate two consumer units via a henly/junction box, but wanted to incorporate an isolating switch so that in future the supply can be isolated without having the main fuse pulled.
My question is, i did not want to add the connection block aswell as an isolation switch and was wondering if I could run two tails with just the isolation switch, I have a 4 pole 125amp Wylex WS124 switch which I was hoping to split...... 2 for live 2 for neutral......perfect for the CU side but how do I link the two terminals (2 Live, 2 neutral) on the input from the meter side.
Any solutions to this setup would be greatly appreciated!
Many thanks
With a pair of henley blocks........
So best do what you first suggested and fit the henleys after the main switch.
Thanks for that.....so no point in using a 4 pole switch, may aswell just purchase a 2 pole one, is 100amp switch sufficient, the main fuse is 100amp
"The main fuse is 100amp"..... (actually it's more likely an 80 fuse in a 100amp carrier).
"Will a 100amp switch be ok?".
I will let you make your mind up after your dinner ;)
Alright alright, yes had dinner now LOL
I know it seemd obvious the switch was adequate but thought that there may have to some spare amps within the switch.....I am pretty sure that the fuse is actually 100amp......we was upgraded about 3 years ago
