In the nearer of the two junction boxes, the cable at the back doesn't seem to be connected to anything else.
Do you know where each of the cables goes?
Where are the earth wires?
And what have you done with all the earth conductors?
Hopefully he has also learnt, or will soon, that what is between your ears is not always right.Thanks taylortwocities, as I said I'm a newbie winston I assumed it was what it said on the tin!
Not your fault but now you have learnt that what is "written on the tin" is not always right.
You mean it has a GU10 base. MR16 refers to the envelope, not the base.That looks like a GU10 lamp. If it has two 'mushroom' contacts that twist to lock, it's GU10.
Nope - if it has 2 pins it's probably a GX5.3 base. It used to be that most GU10 and GX5.3 base lamps had MR16 envelopes, and that's still the case for incandescents, but with the increasing number of CFL and LED ones on the market it's increasingly less so.If two slim pins, it's usually an MR16 although there are other MR sizes.
12v is not low voltage, and low voltage is not 12v. It's actually quite important to get that right. [wiki]Electrics%3AVoltage-Bands[/wiki]GU10 lamps run on direct mains, MR16 are low voltage, usually 12v.
Got any data to support that assertion?Basically, the MR16 fittings you took out are preferable to the GU10 ones you are trying to fit, because they are more efficient,
Why?and being low voltage are safer in a bathroom.
Do you have any definitions of what qualifies as "significant"?Where the installation is old and has not been substantially altered you do not need to upgrade it to the latest standards so long as it remains basically safe, but if you significantly alter the installation, you do.
Jesus wept.[rant]
I would be inclined to fit a traditional ironcore transformer type instead of those poxy PWM types.
Be aware that depending where you live, bathroom lighting work may be subject to special regulations, and may be notifiable to Building Standard.
It was a while before I learnt this tipIf it has two 'mushroom' contacts that twist to lock, it's GU10. If two slim pins, it's usually an MR16 although there are other MR sizes.
As for light fittings, go see what the catalogs list them as.
A GU10 lamp has the pins 10mm apart
an MR16 has the pins 16mm apart
A GU4 has the pins 4mm apart
Can you see where I'm going here?
What can you deduce about a GU24?
Jesus wept.[rant]
Householders call 12v lamps low voltage lighting. LINESMEN call 240v 'low voltage' because they cant get a decent length of spark out of it, as in less than a foot or two. As such, I see no justification for resorting to yet more yuckspeak such as calling it 'SELV' or whatever. At that does is add confusion.
The sensible definition, and what most people would understand, is that if you can get a BELT from it in normal operating, it ain't low voltage.
It wasn't a rant.Jesus wept.[rant]
Indeed they do. And so does much of the lighting industry, retailers etc. That doesn't mean that any of them are right.Householders call 12v lamps low voltage lighting.
No, people who know what they are talking about call it that because that is what it officially is.LINESMEN call 240v 'low voltage' because they cant get a decent length of spark out of it, as in less than a foot or two.
Well, it is SELV, whether you like it or not. It is not "yuckspeak", it is accurate terminology, whether you like it or not.As such, I see no justification for resorting to yet more yuckspeak such as calling it 'SELV' or whatever.
Were we starting from scratch, and looking for terms for voltages from 12V or less up to 1.2MV or more, then it's true that we would probably not have ended up calling 50-1000V "low voltage".At that does is add confusion.
I don't need to look at catalogues to see that plenty of people as well as you are not only completely ignorant of what the various terms mean, they too don't care.As for light fittings, go see what the catalogs list them as.
How can it, when MR16 has nothing to do with the spacing of the pins, and MR16 lamps come with a variety of bases?an MR16 has the pins 16mm apart
